1999-04 F-250/350 Dual S/S Kit Group Buy
NotStock
Tucson, AZ
Starting this thread specifically for this kit. While you guys are working on getting together 10 people, I will finish up the changes needed for this kit. There will be a 2-3 week lead time on these kits and cost will run $265 if you guys can get together 10 people. So far the following people that have shown interest are:
20007.3L
Matt P.
Go Big or Go Home (possibly mulitple)
6.0 P-Stroke
JSchuricht
AZ
Put me down for one. Make it two if it will work on a OBS D60. Also, can I get this without the PMF logo cut in the bracket?
NotStock
Tucson, AZ
Which aftermarket cover Blue? Do you have a pic? It will tie into the diff cover like our 05-13 kits but I have made those points to have as little interference with the cover area as possible. I could give you a better response if I could see your cover.
Updated list, looks like we are at 9 or 10 right now...
20007.3L
Matt P.
6.0 P-Stroke
BlueScab
Super08Duty (2 kits)
Jschuricht
4Duggan
BlueScab
Bristol Tn
NotStock
Tucson, AZ
From the looks of that pic, it should clear. The mounting area around the bolt heads is flat on that cover correct?
NotStock
Tucson, AZ
The only area you may have to make any mods to is around the bolt head itself if there isnt enough room for the center bracket to sit. Shouldnt be much at all though.
For ordering, just call into the shop.
JSchuricht
AZ
So does that mean you have 10 and your ready to take our money?
