2005 F-350 Crew cab long bed
atc500
Utah
2005 Ford F-350 Crew Cab Long Bed Lariat
No tire kickers. This is a solid 650hp truck you can drive across the country doesn’t skip a beat.
170k miles I have receipts for just about everything $25,000
*Titled as a Ford manufacturer buyback.
* Exterior: Original paint in above-average condition for the year.
* Third owner since 2019 Originally a California truck
* Interior:
* Heated front seats
* Power rear sliding window
* Excellent overall condition with typical wear on the driver’s seat
Upgrades & Features:
* Pioneer AVH-2300 touchscreen radio with backup camera
* Alpine Type R door speakers
* Compustar remote start (effective up to 1/4 mile)
* Edge CTS3 with EGT probe and turbo timer
* Pillar gauges for boost, EGT, and transmission temperature
* Tires with a 2-year no-fault warranty for free flat replacement through Discount Tire
Air/Exhaust/Tuning:
* 64.7/71mm turbo (fresh build by Titan, less than 3,000 miles)
* No limit intake
* No Limit cold side intercooler pipe
* S3R intake manifold
* BD exhaust manifolds
* MBRP up pipe
* 3.5” downpipe to 4” straight pipe
* SCT with Warren tunes Max tow,60hp tow, Street, Hot Street and Race
* PHP Economy FICM tune
Suspension & Handling:
* Traction bars
* Leveling kit with Ready Lift track bar drop bracket
* Firestone Ride Rite airbag kit
Fuel:
* Airdog 4G fuel system
* Driven Diesel regulated return/fuel bowl delete
* WDI 205/30 premium injectors
* Thumper 2 HPOP
* WDI high-flow stand pipes
* HHC nipple cups
* UCF O-ring heads
* ARP 425 head studs
* Sinister coolant filter
* IPR EGR coolant reroute
* Snow Performance Stage 3 water/meth injection. 7-gallon tank mounted in toolbox. (dynos 680whp fuel only 710whp with -20 washer fluid)
Cooling System:
* Bullet Proof Diesel 7.3 fan clutch
* Alliant water pump
* CSF CSF7106 intercooler
* All aluminum radiator
Transmission:
* Twisted Diesel Level III transmission with DPC Billet Triple Disc converter (stock stall) Deep pan with 6.4 filter
* PRW flex plate with ARP hardware
Electrical System:
* 250 AMP alternator
* High output alternator charge cable
* 6.7 starter
