2017 Intercooler Pipe Upgrade
We finally got everything finalized on our patent for the 2017 intercooler pipe upgrade so here's the OEM upgrade!
We also have our other style that removes the throttle valve but won't be releasing it until there is a good source for tuning on these trucks. It will avoid confusion and hopefully keep someone from ordering the wrong one for a non-tuned truck. Keep in mind, this version will work on both stock and tuned trucks.
We made a slight change in our 2017 version and it makes it extremely simple. Instead of using the stainless pipe, two boots and four clamps, we just made one single molded hose that only requires two clamps. Not only does it make installation super easy, it also doesn't require relocating the power steering reservoir and brings the cost down as well.
A few key features include-
• 5-ply stainless-reinforced heavy duty intercooler hose replacement.
• Stainless steel t-bolt clamps.
• No custom tuning required. (The tuning required version will be available as soon as someone releases some legit tuning)
