35x12.50x22 Toyo M/T
Swampfox
TN
I've been searching for tires and really want to stay with Toyo M/T in a 35x12.50x22 but the load rating is only 2835 lbs. Should I be concerned with this load rating? Other options are 325/50/22 Toyo AT2 or Nitto Trail Grapplers with a load rating of 3305 lbs. I do not tow very often and about the only thing I tow is a friend of mine's boat sometimes which weighs around 5000 lbs. Any input is appreciated.
Twan
Berthoud, Co
Weigh your truck, make sure and get axles weights.
Most likely you'll be fine. Just don't over laid them to much.
I had. 3,000 lbs tires that final let go, lots of overloaded miles. Cost me a new bed side.
