7.3 DTC Powertrain trouble codes
Powerstroked162
On Da Juice
Wa. State
P0107 Barometric pressure sensor circuit low
P0108 Barometric pressure sensor circuit high
P0112 Intake air temp. sensor circuit low input
P0113 Intake air temp. sensor circuit high input
P0122 Accelerator pedal sensor circuit low input
P0123 Accelerator pedal sensor circuit high input
P0197 Engine oil temp. sensor circuit low input
P0198 Engine oil temp. sensor circuit high input
P0220 Throttle switch B circuit malfunction
P0221 Throttle switch B circuit performance
P0230 Fuel pump relay driver failure
P0231 Fuel pump circuit failure
P0232 Fuel pump circuit failure
P0236 Turbo boost sensor
P0237 Turbo boost sensor A circuit low input
P0238 Turbo boost sensor A circuit low high
P0261 Injector circuit low
P0262 Injector circuit high
P0263 Cylinder 1 contribution/balance fault
P0264 Injector circuit low Cylinder 2
P0265 Injector circuit high Cylinder 2
P0266 Cylinder 2 contribution/balance fault
P0267 Injector circuit low Cylinder 3
P0268 Injector circuit high Cylinder 3
P0269 Cylinder 3 contribution/balance fault
P0270 Injector circuit low Cylinder 4
P0271 Injector circuit high Cylinder 4
P0272 Cylinder 4 contribution/balance fault
P0273 Injector circuit low Cylinder 5
P0274 Injector circuit high Cylinder 5
P0275 Cylinder 5 contribution/balance fault
P0276 Injector circuit low Cylinder 6
P0277 Injector circuit high Cylinder 6
P0278 Cylinder 6 contribution/balance fault
P0279 Injector circuit low Cylinder 7
P0280 Injector circuit high Cylinder 7
P0281 Cylinder 7 contribution/balance fault
P0282 Injector circuit low Cylinder 8
P0283 Injector circuit high Cylinder 8
P0284 Cylinder 8 contribution/balance fault
P0301 Fault cylinder 1 Misfire detected
P0302 Fault cylinder 2 Misfire detected
P0303 Fault cylinder 3 Misfire detected
P0304 Fault cylinder 4 Misfire detected
P0305 Fault cylinder 5 Misfire detected
P0306 Fault cylinder 6 Misfire detected
P0307 Fault cylinder 7 Misfire detected
P0308 Fault cylinder 8 Misfire detected
P0340 Camshaft position sensor ckt.
P0341 Camshaft position sensor ckt. performance
P0344 Camshaft position sensor ckt. intermittent
P0380 Glow plug circuit malfunction
P0381 Glow plug indicator circuit malfunction
P0460 Fuel level sensor circuit malfunction
P0470 Exhaust back pressure sensor circuit malfunction
P0471 Exhaust back pressure sensor circuit performance
P0472 Exhaust back pressure sensor circuit low input
P0473 Exhaust back pressure sensor circuit high input
P0475 Exhaust pressure control valve malfunction
P0476 Exhaust pressure control valve performance
P0478 Exhaust pressure control valve high input
P0500 Vehicle speed sensor malfunction
P0503 Vehicle speed sensor noisy
P0541 Manifold intake air heater...
P0542 Manifold intake air heater...
P0560 System voltage malfunction
P0562 System voltage low Low sys.
P0563 System voltage high High sys.
P0565 Cruise "On" signal malfunction
P0566 Cruise "Off" signal malfunction
P0567 Cruise "Resume" signal malfunction
P0568 Cruise "Set" signal malfunction
P0569 Cruise "Coast" signal malfunction
P0571 Brake switch A circuit malfunction
P0603 Internal control module KAM error
P0605 Internal control module ROM error
P0606 PCM processor fault Internal PCM
P0640 Manifold intake air heater...
P0670 Glow plug control circuit malfunction
P0671 Glow plug #1 circuit failure
P0672 Glow plug #2 circuit failure
P0673 Glow plug #3 circuit failure
P0674 Glow plug #4 circuit failure
P0675 Glow plug #5 circuit failure
P0676 Glow plug #6 circuit failure
P0677 Glow plug #7 circuit failure
P0678 Glow plug #8 circuit failure
P0683 Glow plug diagnostic signal communication fault
P0703 Brake switch B circuit malfunction
P0704 Clutch switch input circuit malfunction
P0705 TR sensor circuit malfunction
P0707 TR sensor circuit low input
P0708 TR sensor circuit high input
P0712 Trans. fluid temp. sensor ckt. low input
P0713 Trans. fluid temp. sensor ckt. high input
P0715 TSS sensor circuit malfunction
P0717 TSS intermittent failure
P0718 Noisy TSS
P0720 OSS sensor circuit malfunction
P0721 Noisy OSS
P0722 OSS intermittent failure
P0732 Gear 2 incorrect ratio
P0733 Gear 3 incorrect ratio
P0741 Torque converter clutch ckt.
P0743 Torque converter clutch system electrical
P0750 Shift solenoid A malfunction
P0755 Shift solenoid B malfunction
P0781 1-2 Shift malfunction
P0782 2-3 Shift malfunction
P0783 3-4 Shift malfunction
P1000 OBDII monitor status
P1105 Dual alternator upper fault (monitor)
P1106 Dual alternator lower fault (control)
P1107 Dual alternator lower circuit malf. (control)
P1108 Dual alternator BATT lamp ckt. malf.
P1118 Manifold air temp sensor out of range low
P1119 Manifold air temp sensor out of range high
P1139 Water in fuel lamp circuit malfunction
P1140 Water in fuel condition
P1184 Engine oil temp out of self test range
P1209 ICP system fault
P1210 ICP above expected level
P1211 ICP pressure above/below desired
P1212 ICP voltage not at expected level
P1218 CID stuck high
P1219 CID stuck low
P1247 Turbo boost pressure low
P1248 Turbo boost pressure not detected
P1249 Waste gate steady state failure
P1260 Electronic positive anti-theft system failure
P1261-P1268 High to low side short cyl.
P1271-P1278 High to low side open cyl.
P1280 ICP circuit out of range low
P1281 ICP circuit out of range high
P1282 Excessive ICP pressure
P1283 IPR circuit failure
P1284 ICP failure aborts KOER CCT test
P1291 High side # 1 (right)
P1292 High side # 2 (left)
P1293 High side open bank No. 1 (right)
P1294 High side open bank No. 2 (left)
P1295 Multiple faults on bank No. 1 (right)
P1296 Multiple faults on bank No. 2 (left)
P1297 High sides shorted together
P1298 IDM failure
P1316 Injector circuit/IDM codes detected
P1391 Glow plug circuit low input, bank #1 (right)
P1393 Glow plug circuit low input, bank #2 (left)
P1395 Glow plug monitor fault, bank #1
P1396 Glow plug monitor fault, bank #2
P1397 System voltage out of self test range
P1464 A/C on during KOER CCT test
P1501 Vehicle moved during testing
P1502 Invalid test APCM functioning
P1531 Invalid test accelerator pedal movement
P1536 Parking brake applied fail
P1660 OCC signal high
P1661 OCC signal low
P1662 IDM EN circuit failure
P1663 FDCS circuit failure
P1667 CID circuit failure
P1668 PCM/IDM diag. communication error
P1670 EF signal not detected
P1690 Waste gate failure
P1702 TRS sensor intermittent circuit malfunction
P1704 Digital TRS failed to transition state
P1705 TR sensor out of self-test range
P1711 TFT sensor out of self-test range
P1713 TFT stuck in range low below 50F
P1714 Shift solenoid 1 inductive
P1715 Shift solenoid 2 inductive
P1718 TFT stuck in range high above 250F
P1728 Transmission slip error
P1729 4x4L low switch error
P1744 Converter not functioning
P1746 EPC solenoid open circuit
P1747 EPC solenoid short circuit
P1754 Coast clutch solenoid ckt. malfunction
P1760 EPC solenoid short intermittent
P1780 TCS circuit of out self-test range
P1781 4x4L circuit out of self-test range
P1783 Transmission overtemperature condition
P1902 Kickdown solenoid relay control circuit failure
P1903 Kickdown solenoid circuit low voltage
P1904 Kickdown solenoid circuit high voltage
Dalton,NH (The White Mountains)
