7.3 zf6 swap
nicholaslaine0
pittsburgh
have an early 99 f450 7.3 swapped it to a zf6 i spliced the 2 wires on the gray plug with the auto harness in use was able to start the truck a few times with the key and it just stopped working replaced the clutch switch and that wasn’t the issue have to jump the starter to start it and can not figure out y it just stopped working any info is appreciated have the manual pcm as well
