webb06
I’ve removed several alumiduty cabs but just curious how everyone is removing the cab bolts? In the past I’ve removed the nuts that hold the insulator to the frame and left the actual cab bolt alone. But doing it that way is a pain to set the cab back down having to realign all of the holes.
Do you guys heat up the bolt head with an induction heater or torch? I just know that if you spin the cage nut on these cabs you have to drill a hole in the floor to access the nut.
Any other tips welcomed as well
