Best tow tune
snow man 22
Ohio
New here and now really sure who or where to go to. I have a 2014 that's been "upgraded" with free flowing parts and have been curious what the best tune would be for towing a 10k enclosed trailer as well as well as a direction to get better tunes. I currently have the sct livewire I use to program then unhook it and use the edge cts3 for monitoring. Only reason I kept the sct livewire is because I previously had a 2012 f150 with custom tunes. Any help would be appreciated
Holeshot
Rhode Island
When towing you would typically want a tune in the 80-100 hp range. Who's tunes do you currently have on the SCT?
snow man 22
Ohio
Currently I have no name tunes from our friends up north. I normally run level 2 or 3 but I was just curious is my egts were to high. Normally cruising down the highway on level 3 doing 70 I'm right around 900-950 and my egt probe is right in the manifold
Holeshot
Rhode Island
What rpms are you turning at 70? Those temps don't seem too crazy if that is when you are towing. Unloaded on a 200hp 10mm tune I am anywhere from 600-850*F at 75-80 mph. My truck as 3.55s as well, so that's around 1700-2000 rpms at those speeds.
snow man 22
Ohio
I have 3.55 as well and I actually went back to stock tire size. I normally tow an enclosed race trailer somewhere around 9k lbs and at 70 I'm around 1700rpm. Unloaded at 70 I'm normally around 800° which I didn't figure was to bad
Holeshot
Rhode Island
Yeah those numbers sound normal. I would keep it in a lower tune setting if you could while towing and keep on truckin.
