Broke centering pin
SaNnDnSurF
SATX
Long story short the centering pin from my block sheared off flush in the spring perch on the axle, what'd be the quickest way to get it out?
mustube
Austin, Tx
I'd probably drill a hole in it and either use an extractor or hammer in one of my chitty torx sockets to twist it out
Sent from my XT1058 using Tapatalk
Zmann
I'd drill it and then it will be ready for new pin your pressing back in there
then even if it was a cast block with the pin as part of the casting you would be set
NotStock
Tucson, AZ
I would honestly consider replacing the block. Its gonna be hard to get the old one out and a new one in that would stay in place properly.
Zmann
good deal I knew you could do it
Trevor just wanted to sell you a set of his cool unitized blocks
:D
