Can I put 22x12s on a f250 with a 3.5 readylift
plat250
Can I put 22x12s with 35x12.5 toyo mt on a 2013 f250 with a 3.5 readylift without rubbing
TripleE44
Keller, TX
Not without a decent amount of trimming. I have 20x10s on 35x12.50s and still rub on the back of the bumper.
plat250
Ok thanks i guess I'll be doing so trimming . I can't go any higher cause I tow a fifth-wheel camper . I was thinking of going 4.5
TheRobenator
GA
I have an 8" Fabtech lift and I put 22x14 with 37"s on it and had scrubbing, the biggest thing isnt the size of the tires but the offset of the rim.
SEABEE08FX4
Montgomery TX
Mines an 08, but I have an ICON 2.5 and 22x12. It rubs a little even though my fenders were already clearanced from when I was running 20x14's, I'm thinking if I go up one more inch I should be fine. For reference I had to lift a Chevy 7" to clear that same wheel and tire combo. I think you'll be fine as long as you don't go past a 35" tire, a lot will have to do with you back spacing and offset though.
BlueWaffle
Grapevine, TX
big diff in the 07 and 08? I'd love to run a 2.5 or 3 but not sure that would clear my 22x12 and 35's without significant trimming
SEABEE08FX4
Montgomery TX
08 and up have a larger front center opening Lance. It might be doable on a pre 08 model but for sure would need more trimming.
SEABEE08FX4
Montgomery TX
Dirty but you get the idea.
Powerstroke214
Baton Rouge, LA
