Zaairman
My truck has started this new trick where occasionally after starting it up, driving a few hundred feet and making a turn, when I hit the brake pedal, it feels like ABS is kicking in and the pedal is hard to push and the brakes don't kick in like they should. Problem is, my truck does not have 4 wheel ABS. The brakes always end up working after I give them a pump, but there is still that quick second of "oh sh!t" when the brakes don't work right away. Power steering and brake fluid levels are fine, PS fluid is maybe 5000 miles old, brake fluid is 3 years old, no brake work since then. No calipers appear to be dragging. Brakes still work fine usually. Just after a start and get moving, the pedal will do this only once. Any ideas?
