DevC
So I have here a sterling rear diff assembly from a super duty I got free, I would be using it in another project, definatly not for my OBS.
It was pulled from a heavily burn damaged truck, 1 rim is still melted onto the hub.
Obviously all bearings, seals races gaskets etc are toast...literaly, but are all the non-wear parts re-useable such as the housing, axles shafts, hubs, carrier, ring/pinion etc?
The pinion still rotates freely along with the hubs, as much as the burnt brakes will allow of course.
