Help! Steering wheel upside down
floridastroke
Florida
Truck fell in hole on jobsite awhile back, after pulling it out the steering wheel is upside down now. trac bar, steering box? Any ideas?
floridastroke
Florida
Thanks guys.... I'm out of town for work but I will look at it when I get back and give an update and the repair.
ToMang07
Mainah!
How big was this say "hole"?
Sent from Prestige Worldwide headquarters!
was big enough I couldn't back out in four wheel drive...... was covered in snow and never seen it
I call BS.... there is something seriously broke or bent....you must have bombed a ditch or something...you didn't just drive into a hole and get stuck to frig it up THAT bad.
I would say track bar or steering box is your best places to start
Yup....good places to start looking for damage. Check everything tho. Bent/broke springs, shackles, pitman arm....everything. Something is bent or broke.
MrMike2010
Long Island, NY
My guess would be a trashed steering box. If you hit something hard enough they tend to twist the splines on the output shaft that the pitman arm attaches to. Plus there's a few other areas in the box that like to twist. Though this is what I have found with the 05-07 boxes. Not to familiar with the obs style.
floridastroke
Florida
As for bombing a ditch , didn't happen! I happen to take care of my vehicle as I rely on it for work here in N. Dakota ..... And as for the hole , it was what we call a pothole here on the pipeline. It is used as a visual locate for existing line's , said pothole was not marked with flags and covered in snow! I was in first gear at an idle as we try to minimize damage to right of ways!...... Anyhow I was finally able to get a good look at things today and it looks like I bent the centerlink, and maybe a tie rod..... I noticed it also turns sharper to the right than it does to the left. Will try and get some pics tomorrow.... Going to order parts tomorrow.
