Sleeper71
I have just installed a Isspro HPOP Gauge. At idol it is 600lbs, cruising at 55 it is 1200lbs, WOT it is 2800 to 3000lbs. The truck is a early 99 with a 15 degree pump and PHP Hydra tunes. Stock injectors, stock turbo with WW2, and AFE Magnum Force Stage 2 intake. Truck runs great but it seems like the HPOP pressures are low. Are these pressures normal or do I need to dig into the truck fund deeper and buy a new HPOP? These readings are on the 80 HP tune.
