HS Motorsports S400 Turbo Kit for 6.7
DieselJpower
Weeki Wachee FL
HS Motorsports turbo kit with a CRT custom built gt45 70/87/1.0
has vband connections at the bottom of intercooler as well as on the hot and cold side pipes
everything needed to install, pedestal, up pipes, exhaust manifolds, down pipe, ic piping, boots/clamps etc.
comes with the no limit intercooler as well
Asking 7k
Located near Tampa FL
DieselJpower
Weeki Wachee FL
There's definitely some lag compared to a vgt or small s300, but nothing a raised shift file can't fix. I've towed with it some as well and it did 850 on the dyno
Workhorse
Ok I have a couple more questions is there any way I could text you if it’s easier
