Leveled 03' F250 Will These Rub - Link Included
mind if I smoke
Knoxville, TN
Ya I'm running a set of 305/60-20 on mine with just a level kit and they rub at full lock so I would be willing to bet a good bit a money they will rub pretty bad.
mustube
Austin, Tx
How wide are the wheels? I have the same tires on 9" wide wheels with 5" back spacing and they rubbed the leafs a bit. You might be able to get away with no rubbing with a 1/2" spacer if those are 9" wide wheels.
ToMang07
Mainah!
37x13.5" tires?????
mustube
Austin, Tx
Yes with 17 inch wheels too. I have 2" wheel spacers now with tons of space and I'm thinking about grinding my steering stops a little.
Sent from my XT1058 using Tapatalk
Daddyusmaximus
People seemed so concerned with tires rubbing the leaves... With just a leveling kit, 37s would probably hit the fenders if the suspension ever flexes when you're off road... and why else would you need 37s if not to go wheeling?
mustube
Austin, Tx
For looks? There's plenty of people who have big tires and wheels that never take their trucks off road, but that's what they like.
This picture is just a leveling kit and 37s. It only ever rubbed the fender once, didn't bend the sheet metal. I have wheel spacers now so it's a different story including cutoff wheels and a grinder.
