Lift kit / driveshaft length.
JohnT24
OXFORD CT.
I installed a 4" rough country lift.
Putting driveshafts in today and rear shaft (at transfer case ) is out 1/2" from stock ....
Question,
Should I have the shaft lengthened 1/2"
Or is there still enough spline left for good contact?
I plan to take it out tomorrow and double check measurements
But pretty sure its just 1/2"
Front shaft is good since its extendable.
79jasper
skiatook, Oklahoma
Trying to recall from memory, that's leaving what, 2.5 or 3 inches inside? Probably fine if you aren't hotroding or off-roading. I seem to remember they were fairly long.
Sent from my SM-G988U using Tapatalk
JohnT24
OXFORD CT.
Yes
Stock it was 3" on the splines
With the lift, I'm at 2-1/2" on the splines.
Ima call it good.
But yeah, the entire tube is like 5" fully splined
Tiha
Super Moderator
Super Mod
Probably fine, driveshaft tubing is expensive, I would try to run it first.
I had to change the bushing in the output housing to take up some slop but been working fine since.
