Mcc Tune file question.
Dzlnut
Idaho
In the custom folder what tune is the F64AENGF.MCC
Is this a stock tune? Does it have any modifications to it?
I believe this is the tune you send your tuner of choice?
Illinois
F64AENGF.MCC is the generic name given to a file exported from the truck to the the SD card.
if you loaded the truck with a stock file, then proceeded to export that file; yes the file would be "stock."
However if the truck was tuned to a non-stock file, and you proceeded to export that file; the file would not be stock.
Hope that helps.
yes, no, yes.
Dzlnut
Idaho
So if I wanted stock power level could I load it in my truck that has no magic muffler?
Sent from my iPhone using Tapatalk Pro
i guess im confused. Why wouldn't you just run the canned tune on the no power setting?
Dzlnut
Idaho
I may end up doing that cause im tired of trying to get g$#rhead to revise it
