My DD build
FaSSt9602
Gilbert, AZ
What are the specs on the HP? I see you don't have a WG on this set up, so I would be curious to see what you went with...
Cutting-Edge Diesel
Newkirk, OK
no its not lol
its a 63/68/83
no wastegate right now. had a gate on it but there was clearance issues so I just capped it off and I will fab one up later before I spray it.
Cutting-Edge Diesel
Newkirk, OK
injectors are in. high pressure is mounted and low pressure mount is mounted. just dont have time to work on the damn thing. plan on running it as the Diesel power super diesel thing in tulsa in September
Cutting-Edge Diesel
Newkirk, OK
got these for it today.
Powerstroked162
On Da Juice
Wa. State
Awesome. I know there's a manifold milled and ready to be welded for this little project. Maybe it'll make it's appearance in OK next week ;)
Cutting-Edge Diesel
Newkirk, OK
Haven't worked on it. Haven't had time. Ran into a snag and fitment issue and that just killed my chances of getting it done. Ill be there with the ranger tho
