Need a Torque Spec !
wahoos
Are they pressed together? Looks like the bolts go into threaded holes to crush a brilo pad looking gasket.
Dzchey21
wyoming
he's right, bolts are only for a lifting bracket, the bolts on the bottom that hold both turbos is all the keeps them together
wahoos
i was just curious if they are pressed together b/c of the brillo looking gasket. I assume they press together and the hold down cleats bolt the assembly to the pedastal and thats it.
How about the torque spec for the bolts that install the alternator bracket to the engine? My manual doesn't have accessory specs.
