It will not be the same, it will be programmed for single shots instead of the splits, not sure how bad it would run though but I wouldnt run it like that for long if anytime at all.
ok ty. i plugged in the edge evolution and im pretty sure it fried my pcm cause when the mechanic plugged in a scanner on the obd it said it couldnt read the codes and should i just get it rebuilt?
