Shaking while accelerating
Randonizer
Have a 2001 F250 with 127000 miles. Has a 6.5" lift and 37s. While accelerating it shakes pretty badly. Only does it at low speeds and seems to only do it in first. It is an automatic. At higher speeds still shakes a little but not much as low speeds. When shifting into neutral and give it gas it does not shake. So it is drive train related. I believe it is maybe the driveshafts or worst case the tranny. Would like some input before i start replacing parts.
It may be axle wrap which traction bars could fix. Also check your carrier bearings and u-joints.
BKopp
Sounds like possible drive shaft crosses. Chock the front wheels, jack up the rear and get under and have a buddy rotate the wheels back and forth is a good way to see what the drive shaft is doing
Sent from my iPad using Tapatalk HD
David N
Eastern NC
My stock height truck did something similar to that when I put the new motor in. Turned out an injector wasn't plugged in 100% correct. But I was getting a CEL with mine.
Randonizer
It just started the other day. Had the lift on for about two months now. I'm gonna replace u joints see if that works
Sent from my SCH-R530U using Tapatalk
Randonizer
did it just start or has it been doing it since the lift? carrier bearing drop?
Carrier bearing drop wont work since I dont have one. I have a short bed extended cab which has no carrier bearing. Turns out bolts in my tcase were loose causing it to shake. No idea why they came loose though.
