Steering gear box!
BSalisbury
I’ve read where 2017 stock gear boxes will work on the 6.4 with just having to drill the holes bigger! Does anyone know which gear box will work I understand there is several different ones on the newer models!
Any input will be greatly appreciated!
Thanks
Roccafellas
2011-2016 not sure about 17
Just make sure your build date is after 08/08 or else you will not have the same type spline for the steering column.
Any 11-16 will work and is updated with a tighter recirc ball.
11-16 will be a direct bolt in with no drilling which I would use as you could harm geometry angles with drilling and or risk snapping the casting.
BSalisbury
Build date 02/07 so what are my options there? Was planning to get gear box from salvage yard!
Roccafellas
Just checked The boxes are up to 07-30-2007
And then after 08-01-2007
So by what you said you are 02-2007
So you can not upgrade your box unless you get a new column. Or replace the end.
You would need to be 08/07
Sent from my iPhone using Tapatalku
