Steering wheel intermittently wont return center
DEEZUZ
NO PUKESTERS
NWI
Few times now Ive been caught up after making a turn having to correct the wheels straight. Its only happened a handful of times and is very few and far. I do notice my left front tire has alot of inside cupping going on. I know this thing needs an alignment but I was going to wait until I got new tires before I do so.
Am I looking into a sticky ball joint or tie rod end? The truck does have a newer Red head
yup
DEEZUZ
NO PUKESTERS
NWI
Ill get the front end up tomorrow, see how hard it is to disconnect center and see if a side is favoring. I need to give a few turns anyway to center steering wheel.
DEEZUZ
NO PUKESTERS
NWI
Will do, It did it today while merging onto Highway. Will update. Thanks
DEEZUZ
NO PUKESTERS
NWI
They should not be turning though when their not locked...?
DEEZUZ
NO PUKESTERS
NWI
Crawled under neath there to unbolt the stabilizer and decided to hand spin the U-Joints. The left side would bind up solid in one spot while the right side would free spin 1/4 turn when turned fast enough. Sprayed some ZEP in each cap and turned it by hand and it kept getting easier and easier to turn. So looks like I need a joint. I guess my axle shaft still might be getting caught up on the rough spot I had on it from the inner axle bearing failure I had earlier this year int turn making me feel this only sporadically.
thanks guys.
JCart
In axle u joint roll over all the time (regardless if hubs in or not) and when they seize they will affect steering re-center. Generally first thing I check if steering does not recenter or if stiff.
jrc
