My DD build
Cutting-Edge Diesel
Newkirk, OK
doing alot of work on my 06. Its getting a entirely new compound set up. Running 66/74/.91 and s483 for the turbos. Also getting a set of Steed speed manifolds, industrial injection new hybrid bodies, injectors that flow 315ccs, Fresh stage 3 twisted tranny, RCD oil filter relocation kit and a new FASS pump
BullsEye
Looks good. Following this build to the end. Look forward to it being complete
Dave
315's in a DD. Im guessing you dont plan on any towing? Even with your set up that may get hot
Cutting-Edge Diesel
Newkirk, OK
well that may change... Opened up another set of injectors I had and may change shims and make them a bit smaller... maybe 285 hybrids.
This truck doesnt tow... got a 6.7 to do all that I wanna do. This is just a street truck. If it spools good I may hook it to a bumper pull and see how it does.
Pizza pig
MD
the vband steed speeds are way nicer than the three bolt flange.
Cutting-Edge Diesel
Newkirk, OK
finally decided on injectors. going to have the oil side of a 205 to keep Icp up and smoke down, with 150 nozzles. making them 265cc (I think) hybrids.
