Go Back   PowerStrokeArmy > Power Strokes > 6.4 Tech
Reply
Thread Tools Display Modes
  #1
Old 02-03-2020, 04:43 PM
Laxman1306 Laxman1306 is offline
Private
Member's Gallery
Default No boost... performance wastegate issue?
So just got done installing my new motor and was hoping the boost issue I had the last time I started the truck before I tore it down was something wrong with the motor but Itís still not building boost. I did put a scanner on it and got code p2262 and p2263 which is a turbo performance failure... I did try another MAP sensor and it made no difference and the EBP sensor is working fine... I split the turbos and replace the gaskets between them and the seals that go through the elbow and small pipe under the fuel cooler.... the turbos seemed fine and spun freely and had now slop to them but Iím wondering if there is something wrong with the secondary precision turbo set up I have on it... any help with this issue would be great.
This is the set up I have.
Sent from my iPhone using Tapatalk Pro
  #2
Old 02-03-2020, 05:14 PM
EPA EPA is offline
Sergeant
Member's Gallery
Default
You got the fire ring on the wastegate??
  #3
Old 02-03-2020, 05:33 PM
Private
Member's Gallery
Default
Quote:
Never took anything apart when I pulled the engine... just undid the clamps and removed it
  #4
Old 02-03-2020, 05:37 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Is your vgt actuator plugged in? Does it do a full sweep when the key is cycled?
Could always remove the waste gate entirely to eliminate the possibility.
  #5
Old 02-03-2020, 05:46 PM
Private
Member's Gallery
Default
The vgt is plugged in and the actuator cycles when the key is turned on
  #6
Old 02-04-2020, 06:29 AM
Private
Member's Gallery
Default
Yes the vgt is plugged in and moves as it should.... the truck did this the last time I started it before I pulled the engine for the rebuild.
  #7
Old 02-05-2020, 06:27 AM
Private
Member's Gallery
Default
So I took the dump pipe off the wastegate last night and no pressure is coming out so that rules out the secondary wastegate issue... so whatís next? I pulled out the ebp sensor and the tube both were clean... cheacked the map sensor again everything is good there... is it possible these turbos are junk?
  #8
Old 02-05-2020, 08:34 AM
EPA EPA is offline
Sergeant
Member's Gallery
Default
So I took the dump pipe off the wastegate last night and no pressure is coming out so that rules out the secondary wastegate issue... so what’s next? I pulled out the ebp sensor and the tube both were clean... cheacked the map sensor again everything is good there... is it possible these turbos are junk?
This doesnt rule out the wastegate. Pressure will be very different at idle then driving down the road.
But I would do a boost leak test on that truck before digging any further.
  #9
Old 02-05-2020, 10:02 AM
Private
Member's Gallery
Default
Itís not that Iím leaking boost itís the turbos arenít even operating and are even trying to spool up
  #10
Old 02-05-2020, 10:07 AM
Private
Member's Gallery
Default
And I had this issue the last time I ran the truck as well after is sat for a month
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
