Plenty of fuel
Bryce_fow
So I finally got around to doing the fass and titan tank
The fass is a pain in the ass on the 17+
The titan is easy and pretty straight forward
I didn’t feel like modifying my sending unit so I put a sump just Incase I ever have to go back stock
Bryce_fow
It’s close but I can live with it I will take more when I get home
co04cobra
WV
I see it now. Will be interesting through a couple winters or off road use if any issues arise.
Bryce_fow
I will let you know haha I am off road almost every other day with our forestry business
Black AOD
Ohio
OP, what's your reasoning for doing the FASS? I assume you wanted/ needed the extended fuel range so you did a bigger Titan tank, that I get but the factory filtration is pretty good on 6.7, just curious why bother with the FASS? Are you planing on making more than 700whp?
I've given it some thought on doing one on my truck but have decided against doing it since I wont ever be doing more than 650-700WHP on this truck and that's honestly more than it will need anyway.
Bryce_fow
I have had a fass on every truck I have had so while I was there I went ahead and did it because they have never let me down and I live in south ga so not always the best fuel quality ha so filtration is key to me. And no I am not going past 600 or don’t plan to for a while
I know fass isn’t a custom built setup like people like on here but it has never let me down and I can drive worry free as far as if it does go down out of town I can make a call ( all ways professional staff and very friendly ) and get me back on the road
Black AOD
Ohio
Fair Enough. I was just curious.
Bryce_fow
So update the fass doesn’t work with a titan tank if you turn to fast or stop to hard it can’t get the fuel from the sump and looses prim so I am trying to get it sorted out thinking of taking the fass off and putting a afe pump on
06FX4
Miami Fl
I want to say i read the new s&b tank has a baffle inside to prevent the sloshing. Without the baffle and a sump will most likely happen with any pump
Bryce_fow
This tank has a baffle also I did see the s&b and I like them but already have this one
