Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #21
Old 07-11-2018, 05:32 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
I'd love to see the upper hose temp compared to lower
__________________
Teamsters Local 444- Rolling Coal United
  #22
Old 07-12-2018, 06:16 AM
Jtreece's Avatar
Jtreece Jtreece is offline
Sergeant
Member's Gallery
Default
just picked up 2 OEM radiators last night so the mishimoto is getting pulled soon. Also the upper and lower radiator hoses are new.
__________________
04 F350 CCLW SRW, 35's, CM skirted flatbed, Diablo T1000, SCT3, Studded, *******, 4", Stage 2 Tranny, blue spring, wicked wheel, loves to eat Hondas.
  #23
Old 07-12-2018, 06:18 AM
Jtreece's Avatar
Sergeant
Member's Gallery
Default
Also, both the radiator and cooler are clean (oil cooler brand new) and the system was flushed before install.
__________________
  #24
Old 07-12-2018, 06:22 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
I'm saying I'd like to see what's going in and what's coming out. For example, if the coolant is just whipping through the radiator, it isn't dissipating the heat properly and leaves radiator too hot.
Also, if there is a big spread in upper and lower temp, then there is too much restriction in the tubes, keeping hot coolant in your block alot longer
__________________
  #25
Old 07-12-2018, 08:03 AM
Jtreece's Avatar
Sergeant
Member's Gallery
Default
ohh I got ya, I will have to do some checking. And you say restriction in the tubes as in the radiator or the oil cooler?
__________________
  #26
Old 07-12-2018, 08:36 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Radiator. Alot of cheap chinsy radiators are found with pinched tubes that retrict the flow too much.
__________________
  #27
Old 07-12-2018, 08:38 AM
Jtreece's Avatar
Sergeant
Member's Gallery
Default
I'v been hearing that, kind of glad I picked up 2 OEM radiators yesterday.
__________________
  #28
Old 07-13-2018, 06:06 AM
Jtreece's Avatar
Sergeant
Member's Gallery
Default
got a question, started my truck this morning after it set for over 16 hours and the ect and eot were at 90 and 91 when the ambient temp was 75. Shouldn't they read what ambient temp is? this may be a dumb question so sorry if it is.
__________________
  #29
Old 07-13-2018, 06:41 AM
Decker's Avatar
Decker Decker is offline
Sergeant
Member's Gallery
Default
Nope, usually will be little warmer then outside temp.
__________________
06 F350 CCSB King Ranch - For Sale
Studded, *******, upgraded banjos, blue spring,
6.7 fuel pump with sump, swamps 58v ficm
4in turbo back, coolant filter, guages, CAI,
SCT w/ IDP & TSD tuning & PHP ficm tuned
04 F250 CCLB XL - Sold
  #30
Old 07-13-2018, 06:46 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Man... After 16 hours I'd think they should be within a few degrees of ambient...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
