Parts required for egr delete and studs?
LiftedBlackHD
I plan to do studs, weld the egr shut (smog check) and replace oil cooler.
What parts do I need to include all the new updates?
Thank You
04stroker
Sarasota-Bradenton, Florida
Well...
studs
head gaskets
rocker box gaskets
valve cover gaskets
intake/exhaust manifold gaskets
oil cooler
turbo gaskets
Injector O rings
"blue spring"
I am assuming you do not need STC fitting or dummy plugs with your build date. Let me know if I can help we do packages for these kits.
