Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 05-14-2019, 06:44 PM
bigbill78 bigbill78 is offline
Private
Member's Gallery
Default Brake lights don't work
I have an 02 f350 drw 7.3 that the brake lights don't work. Blinkers, flashers, tail lights all work. But no brake lights. I have replaced the brake switch and it blew at brake switch not the fuse. On the brake switch the terminal for brakes is burned. Also my electric brake control don't work and my left blinker is lit when lights are on. Anyone have any ideas?
Sent from my LM-V350 using Tapatalk
  #2
Old 05-15-2019, 08:47 PM
greyford1979's Avatar
greyford1979 greyford1979 is offline
Major
Member's Gallery
Default
Did you check the wires at the back of the truck underneath near the frame? I had issues with my 2000 F250 like this. The harness was rubbing on the frame and rubbed right trough the insulation causing a short. I ran all new wiring from that spot. I didn't have any issues with the brake switch though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
