My personal compound build
Cromwell, CT
lets get this build mostly up to date here
got the S467 mounted all up to the RCD T4 kit and it clears my fitting into the test port perfectly
clears with the cab down perfectly
relocated the vacuum system to the frame and replumbed the system to work down there
powerstrokedkid87
New Jersey
by the time you get this thing done...il be taking mine apart again lol.....looking good tyler, really cant wait till you get this thing back up and running!
Cromwell, CT
I know you will be nothing new there tho lol, and yeah I only had to lengthen 1 vacuum line everything else worked perfectly, had to move the actuator tho after it was in the way of the 4 link mount all good now tho
