Injector rattle
brewster
Curious as to why especially on a colder engine when I'm accelerating normally around the 2000rpm mark the injectors rattle real hard. The injection sounds changes dramatically and sounds horrible. Is this the pilot injection ?
Jsexton
Alabama
I have the same problem with my 6.4. I hate the noise. I wonder if their is a way to alter the pilot injection to clean up the injector rattle.
ckrueg
Belding MI
I'm pretty sure it's because the pilot injection cuts back a lot around 2k+ rpms. I added them back somewhat and it helped
tnutcher
What tables did you adjust for the pilot injection? Only one I'm seeing with noticeable drop after 2k rpm is the pre inj. 2 activation map. Any downside to running it the same as the pre inj. 1 table above it?
Sent from my SM-G900T using Tapatalk
ckrueg
Belding MI
Yeah on my tunes i had turned them on all the way up in rpms. I did turn them off under higher torque however
Azraie218
depending what BASE file the tune was built off, HS for some reason pulled some Pre injection 1 fuel amount from the table in some of the tunes... thats the one that will casuse you to hear that sound.... they puled it right around the 2000RPM mark in the upper load range. ensure that your activation maps are on ( set to 1) for the pre injection 1 maps, ( dont worry so much about pre injection 2 activation tables in the upper RPM) then go over in to Pre inj. 1 mass fuel commanded Temp 0, and temp 1 and ensure that there is not 0s in the area of the rattle ( likely if your getting a rattle there will be no commanded mass fuel amounts) ... if there is 0s start adding fuel till it shuts the rattle up and makes a happy sound ( if you have access to the tune thats in to the truck, im assuming that its got custom tunes if your running a single with bigger sticks) .
TD-5
British Columbia Canada
They also changed the timing (BTDC) in both pre injection 1 & 2 tables. Mostly increases but also some decreases in timing.
ckrueg
Belding MI
That timing map looks odd for a pilot timing map. Should be way more advanced than that. Stock is 15-30 degrees most of the time
TD-5
Sorry, that's using the compare difference function between the H&S 300 map & the stock Map.
these are the actually maps
brewster
Thanks for the response guys, sorry for the delay i was away for work. I forgot to mention that this mostly happens or is more audible on a cold engine. Even accelerating lightly it is super loud.
brewster
how come i dont see an option to post my files / images. was going to post the tune or images.
brewster
never mind, got it figured. Curious is the lower fuel mass in the lower rpm and torque range will give the rattle sound and if adding more fuel might help clear it up. Also where does post injection come into play and why is it mostly off. Post injection used for *** regen ?
Kind
Yes, post injection is primarily used for emissions.
On other platforms people have used it to help spool chargers but we are unable to do that.... I tried lol.
#letsgochamp
Diesel625
Mine did that as well with the ghead tunes I ran. The truck had 140k when I finally ******d it. It seemed to get worse when the miles piled up. I tried the tow, street, and hot street. The tow with the least injector rattle. I put a set of ford reman injectors at 175k and the sound got very quiet. That was with the street tune.
brewster
Yea I'm thinking there is an issue with these injectors. Not impressed with them. Haven't been able to get rid of smoke and have pretty hot egts soon as I put my foot into it a bit. I I know having a non vgt has a lot to do with it but ddp claims these 50hp are a direct drop in with less smoke and more mileage then stock injectors. I have yet to experience any of that lol. I should have just bought brand new stockers as I'm not looking for the most power I can squeeze out of it.
Powerstroke Man 6.4
If you are stock single HPFP and anything over stock nozzles, that's the reason of all your issues.. (egt, smoke)
Pull back PW or get a dual fueler if you want to keep the nozzles.
Other then that put the stock nozzles back on.
brewster
Really hey. Why would the 50hp injectors cause an issue with the stock hpfp. Is there not enough fuel or the fuel not atomizing properly. It was holding 25k psi pretty good. How would doing a dual duel set up help the smoke and egts. I think I'm heading back to a stock injector pretty quick here as it makes plenty of power for my liking and id like to be able to tow my boat with it anyways.
poor atomization as the single pump cannot maintain rail pressure.
