Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 06-11-2019, 06:16 PM
JCart JCart is offline
Sergeant
Member's Gallery
Default ZF S5-47 in, need suggestions on DSs
Hey Fellas,
Looking for input with questions.
Given I have to have a rear D shaft made up to accommodate ZF swap into Tan truck ECLB, with 3.5 RSK, blocks in rear to level. Im thinking of doing (1) single shaft, so need input from guys that have done this and (2) did you use the stock shaft ends or upgrade to SD flange on TCase rear out put and if so will one fit the BW 4407? And (3) Will rear yoke from SD fit the OBS 10.25 pinion?
Im thinking the SD style 1/2 cap on the rear yolk will be stronger then the OBS strap?
The OBS TCase output flange has a smaller dia ring on the flange then the SD flange so either change to SD flange (if it will fit a BW 4407). Or alternatively make a spacer to accommodate the OBS ring on stock flange and put the SD ring on the output side of the spacer to fit SD universal, hope that makes sense....
Lemme know what youve done. Slowly setting rig up to 450-500 RWHP range to be used as DD that tows if needed to 7-10k lbs.
Thanks Guys.
__________________
'97 F250 ECLB Tan White Tan E4OD, 4:10s, D60, PMF 3.5 RSK, Anti sways front/rear w rear bags 5 blocks (129,000 Kms) DP, intake and 4 exhaust.
Truck pix & Write ups
  #2
Old 06-12-2019, 10:25 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
I wouldn't worry about straps and flanges. Just make sure you use good u joints. Spicer or oem which are spicer..
live life full throttle
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #3
Old 06-12-2019, 01:40 PM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
CCI Driveline for the shaft. They know theyre stuff. Just call and talk to them and theyll get you what you need.
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #4
Old 06-12-2019, 05:51 PM
Sergeant
Member's Gallery
Default
Yup Spicer with the grease fittings is what goes in, learned my lesson trucks ago.
Thanks for comments
j
__________________
  #5
Old 06-12-2019, 05:58 PM
Sergeant
Member's Gallery
Default
Quote:
Thanks for the suggestion. Will use someone a little closer to home as I reside in Western Canada. Shipping (in Canada), cross border bull ****e, exchange with USD, makes a lot of stuff cost prohibitive like 40% or more.
Thanks for suggestion though appreciate it.
j
__________________
  #6
Old 06-19-2019, 10:04 AM
Sergeant
Member's Gallery
Default
Kept ‘er stock two piece, full replacement new including, slip joint, mid bearing, tubing spicers etc.
__________________
  #7
Old 07-01-2019, 11:24 PM
m_j m_j is offline
Sergeant
Member's Gallery
Default
likely better for the length.
  #8
Old 07-02-2019, 04:40 PM
Sergeant
Member's Gallery
Default
Working top drawer, albeit a little noisier due to rollover in gearbox, new turbo internals and 1.0 A/R make for better overall performance. E fuel fed into rear of heads runs as expected... smooth to redline. IC next, then jectors, (with T500 on shelf), pending how hot it runs might include water injection with large tanks custom made to fit between box fender skin and frame at front of box.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
