78-79fordman
- Joined
- Feb 13, 2013
- Messages
- 51
- Reaction score
- 0
ok I went dual fuel Bosch pumps setup regulated return from 444fab . here's the pump setup in pics . I'm running stock injectors as of now but will be upgrading to 238/80 in the next couple months when I get the funds saved . starting with fuel since the stock pump started leaking .
so the questions
can I hook up the secondary pump to a pressure switch on the regulated return. if so what pressure should I make the secondary pump kick on . and in pics u can see the one way check valve is installed on the top pump . should it be the primary or secondary pump.
so the questions
