Hmm, what mod(s) to do to this new heap?
08Monster
Can I see some pictures of the MPD filter relocate?
Sent from my Moto Z (2) using Tapatalk
jcain
Hit the Dyno at scheids. Pulse widths were 800 us, 1100us and 1500us
As a reference, there was a tune ****** 15+ on kill tune that made 597 and a tune ****** 66sxe seap with dual.fuelers 15+ that made 671.
https://youtu.be/c2oBUz8wUAg
jcain
Wastegate fab'd in. Time to party. Also started getting the stand alone data logging stuff in.
jcain
Put down 874rwhp this weekend at the Morgan Primm fall brawl event. Had a wicked exhaust leak and boost leak. Turns out I had blow up pipe gaskets, blow up pipe Bellow and blown wastegate bellow. Took the cab off and had a fun couple days fixing everything.
08Monster
Sorry to bother again but could I see that fuel filter relocate you mentioned early? MPD said nothing was available, and I need something like that to work with my dual fueler setup with the MPD piping kit. Doesn't all fit and work with the H and S fuel filter kit.
jcain
More robust bottom end and top end, more air, more fuel, more trans
jcain
It made shy of 900rwhp and the injectors we're only at 1700us and 14* of timing along with ALL of the issues. I bet it would've been close with the 60s maxed out. I'd say it'll be well past 1000rwhp this go around.
alewis
Are you planning to use some of the new MPD products on the bottom end? I am curious to see what kind of power can be made and held with their main caps, girdle and whatever else they recently developed.
Thanks for sharing the detail on your build!
