hoosierdiesel
Well I just finished up draining the water and cleaning out EBP tube. I've seen a few posts on removing that egr cross over pipe but nothing in depth. It looks like it may be possible to remove it cab on . I am curious as to why that isnt removed when you do the EGR delete. The pipe has no purpose once the egr is deleted... So who has removed that pipe? Were you able to do it cab on?
Also one you move the block off plate up top there and tap in a port to relocate the sensor can you use the whole tube or should I shorted it up? This may have been covered somewhere but in my search on here, the .org, and the nation I couldnt find anything good.
Secondly I'm ready to do the CAC pipe and elbow. There is quite a bit of stuff on the stock elbow. Is all of that completely removed? I know about the egr valve and related junk. But is that all egr related on the stock elbow? Sorry for the long post and I appreciate your help.
