Derek@Vision Diesel
Kit has 0 seconds of run time, brand new!
Keep your AC and factory coolant bottle
All that is required is modification of inner fender on passenger side and battery relocation.
All piping was done by Irate Diesel.
Turbos are spec'd and built by Pius at Bell turbo.
-Atmo: PDSB- 1700cfm- T6 open housing- 80mm compressor
-Primary: ZQ Wheel s300 with 360* thrust- 1150cfm- T4 - 64mm compressor
(2) turbo smart 50mm progates
All oil drain and feed lines.
T4 Irate up-pipes
Comes with down-pipe
Will Fit any 99-03 Superduty or Excursion.
Ready to bolt up and run. Over 75 hours of labor invest in building this kit to fit perfectly. Built to spool great and make great fuel only numbers. Nothing was spared in the creation of this beautiful kit.
$10,000 OBO
T4 Irate up-pipes
$10,000 OBO
