Help...Manifold to Up-Pipe Bolts Siezed.
ToMang07
Mainah!
So I had recently developed a leak in the up pipes behind the collector. Big surprise, right?
Well, a 6-point socket was spinning on the collector bolts (probably from rust) so I decided to cut the manifold to up pipe bolts. Got the up pipes off/out. Well after and MAP gas torch, I can't punch ANY of the bolts out.
As anyone who has done this can attest there is little to no room to get to the bolts. (I have the down pipe removed.)
I need ideas. At this point I'll try a few more doses of hot wrench and PB Blaster, but if I have to do the manifolds I'll just pull the engine, since chances are there will be at least one stuck bolt there, too. I really don't want to go that, but eventually I'll need to install my new oil pan anyway.
ToMang07
Mainah!
Able to get a oxy/act set up in there? Going to take some coxing to get them out, on a few sets ive used a air hammer to do it.
I have never welded nor own any equipment to do so. I guess I can ask my neighbor if he is willing, but he's an older gentleman...probably pushing 70, not sure he wants to be crawling around on the ground, let alone moving all his equipment. :fustrate:
co04cobra
WV
If you think there is any other bolts stuck, or want/need to do other work, you'll be time ahead to just pull it.
Really the only other option is to torch them out, unless you are very good with a drill. As you already know there is not much room for that.
ToMang07
Mainah!
I'm leaning that way. I have another year or 2 before the oil pan (likely) rots through. I'd prefer NOT to do it unless I have to, but at this point, IF I can get a real torch/welder in there, that's my only option other than having it towed to/from an exhaust shop. :fustrate:
ja_cain
I have removed broken bolts by first welding a washer with a smaller id than the od of the bolt to the bolt. Then you weld a nut to the washer which allows you to put a wrench on it and break it loose. The heat alone of welding all that will usually make it easy to break it loose. Probably not enough room in there to do all of that though. Sorry if this was not helpful and good luck. Probably best to just remove the motor then do what I said.
Arisley
Arlington, Texas
Not a real option.
If the huts were turning with a ratchet, they are loose and will punch out. Soak with PB Blaster or your choice of lubricant. Stick a short punch on there (small stock held with a vice grip), and hammer on it. It will give up and allow you to win.
ja_cain
Not a real option.
Sound like a good idea. I guess I'm not familiar with how the up pipes are bolted to the manifolds. Are they just a bolt with a nut on the other side? If that's the case, then they should pop right out with enough pounding like you said.
ToMang07
Mainah!
Not a real option.
I tried that, took a big azz nail, cut it and used vice grips to hold it....pounded the **** out of it. Hasn't budged a hair. I'll try again tomorrow, but I'm not holding my breath. Gonna soak it with PB Blaster again tonight when I get home from work.
You'd think so, right?
buschpoweredstroker
Upstate NY
No real trick to it, soak it, heat it, beat it until you give up or they come out. If you need to do the pan at some point anyway you might as well yank the motor and do manifold gaskets and oil cooler gaskets and seals at the same time. You might want to invest in and learn to use an oxy/acetilyn torch or you probably won't get too far on the manifolds, that first bolt that you snap off in the head is gonna make your heart sink if you don't know how to get it out. You can pull the tranny and get yourself some more room also.
psduser1
on the road
You can pull the manifolds with the engine in the truck, but it's a b!tch if you don't have oxy-acetylene, tom. If you need gaskets, just pull the engine, do it all at once! I've done all that work both in and out of the truck, and for the aggravation, it's worth pulling it!
ToMang07
Mainah!
Yeah, I'm leaning more and more towards pulling it. Gonna try a couple more things tomorrow, but if I can't get them out...probably going to pull the engine this weekend. I'm sure the manifold bolts are about as bad as the up-pipe bolts were, so no way am I attempting to do that with the engine in the truck.
redneck1
Nor Cal
Drive the truck around everyday for about a week. Spraying every bolt you want to take out every day. Get some good mechanics gloves and work them after driving the last day. That's what worked the best for me. Just my experience. Also why I got scars from working with mine, lol. Anti seize any bolts going back in!
Yea. Im ready to pull the motor in hour half...
Just cut the manifold bolts off behind the manifold. I used a pipe wrench to get them started. Then if they got loose enough turn em out with adjustables or lock a vise grip on the nub and finish.
The one center hole is tight and an alignment tool. You will probably have to drill it out. Dont bother beating it.
Zaairman
Wright City, MO
Heat (lots of it) and an air hammer. You've already got the front part of the truck off, you're only a few bolts away from pulling the whole thing out, might as well and do the oil pan while you are at it. The up pipe bolts are much easier with the motor out and you are finding out why.
