Travish3's Projector retro fit guide(PIC HEAVY)
travisH3
Cincinnati, Ohio
ok heres my projector retro fit. All parts were purchased through the retrofit source. Ill post links so you can see what you need for the job.
projector retro fit kit- I used the morimoto mini d2s x lens(square lens) 35 watt ballast with 5000k color temperature bulb, h13 wiring harness with sqaure gatlin gun shrouds.
Bi-xenon Morimoto Mini Stage III Kit (D2S)
3" xb led amber strip
Morimoto XB LED Strips - Accessories from The Retrofit Source Inc
80mm housing caps- these are needed for the back of the lights to seal them up because the bulb will protrude out the back of the light so these allow you to seal up the light and give some extra room for the bulb/plug
Rubber Housing Caps - Accessories
ok lets get started, first you need to bake the headlights apart, remove all bulbs, rubber seal around headlight bulb socket, and 3 screws are recessed into the back of the head light. 2 hold the top reflector, the other one bolts to the lens assembly so its best just to remove them all now. Ive baked a few headlights and these were by far the toughest to get apart. the factory butyl doesnt really get soft and sticky, its just barely softens up. normally i do 265 degrees for 7-8 minutes and if needed i will do a second cook same amount of time because the butyl starts to cool down and harden, the second cook it usually comes right apart easy.....not ford oem lights lol. it took 2 15 minute cooks for one light and 3 15 min cooks at 265 for the other. and you really have to work them hard to get apart. be careful, everything is warm and dont pry too hard in one spot, keep working a corner until you start getting it free then you can work it all the way around so, pre heat to 265, turn oven off and bake for 15 minutes twice and see how they are, you may need to do it a third time like i did. you wont hurt the lights at all.
when your done you should have something like this
there will be 3 screw holding the reflector to the lens, and then another 3 screws holding the chrome surround to the lens. next i started sanding the surround to prep them for paint. DO NOT USE BRAKE CLEANER ON PLASTIC to get them clean for paint! , the plastic crumbles. luckily i bought a set of headlights off ebay to use the clear reflectors and the surrounds were the same so i was able to use the chrome surround from the ebay lights on my oem lights. (i planned to use the ebay lights but found out after taking them apart the adjuster screw was stripped out and i didnt want to risk all the hard work on cheap headlights.
after getting that mess sorted out i used rustoleum plastic primer and semi gloss black to paint the surround.
primed
semi gloss black
next start working on the headlight sockets,
****WARNING: test high beams with 9v battery. they say to test the high beams operation with a 9v battery 40 times clicking it on and off. if the mechanism is faulty it will fail in the first uses so by engaging it 40 times you wont get it all together and realize high beams dont work on the projectors. you will hear a click and you will see the actual cut off shield moving in the projector.
the d2s projectors are slightly bigger than the bulb opening so you have to use a dremel to open them up, if you use the mini h1 projectors you can skip this step but you will still need to sand the back of the reflector housing down to allow enough threads for the shaft of the projector to fit through the light. this will make more sense once you have the projectors in front of you. my dremel job wasnt perfect but it works lol. i did all trimming without removing reflector bowl, i just found it was easier that way, just make sure you blow out all the shavings good. you will need to remove the bulb cap in the reflector housing and i also sanded off the little block where the bulb cab bolted to the reflector(you can see the black square is where i sanded it off. this will be hidden behind the projector, there will be a hole in the square as well so i ran my high beam wires through there. you will also need to drill a hole for the high beam wires to pass through the housing either through the housing it self or putting it through the dust cap at the end. i chose through the housing and will silicone the hole after cooking.
test fit projectors and shroud to see what it would look like cuz i got excited lol.
Now the not so fun part. installed the projectors in the light housing and took them out to truck. went ahead and ran my relay harness and ballasts. connected the headlight bulbs and popped the headlights into place. with the head light reflectors adjusted to the center of the adjustment range i wanted the headlights to be close to where they needed to be. this way the lights willl have full up and down adjustability. youd hate to do all this work to install them and realize you have them pointed too far down and they wont adjust enough to get them where you need it. for my lights i had to sand the back of the reflector housing at the bottom to get the projector to point up more. in the end i still wasnt happy so i used and extra piece of projector rubber bushing and put it at the bottom of the projector so when you bolt it up, the projector points up. its hard to explain but heres pictures of what i did.
as you can see i pulled the bushing off and glued another piece of rubber to the projector so when you put the bushing back on and bolted it up it points up.
after doing that i was happy with the range of the adjustment.
here is a picture of the projector tighted down, and bulb installed into projector
here is a picture of low beams
high beams
here is the low beam cut off line along the garage, no hid glare like when you just install bulbs in oem housings!
now that projectors are installed and aimed, i installed the painted surround into the headlight lens. be sure to wipe the lens clean before doing this because once the surround is in it will be hard to clean it well. then i installed the reflector. you should have something like this.
next steps may not pertain to you unless you want to add custom led strips. i bought a 3" amber led strip to use as a running light. what i did was used tape to move the light around and get it where i want it. here is a pic of it lit up when i first opened the lights to see how it would look. its really bright, pics dont do it justice. these were just tested using a 9v battery again.
once i got the led where i wanted i pulled the film off the double sided tape and stuck it down. afraid the tape may not last i decided to epoxy the led down to make sure it doesnt move. i also epoxied the wires down in one spot to be sure i dont accidentally pull the wires on the led. just to be safe. drilled a hole for wires to pass through, i will silicone the hole up after baking the lights back together.
finally lets put these back together!
Butyl that came with the kit, i bought an extra roll to be safe but the roll that came with the kit was PLENTY, like there was enough to do a whole other set plus my extra roll i bought lol. I used a heat gun and cleaned the channel out removing all the old junk butyl that ford used since it isnt very soft. just be careful not to melt the plastic..... :doh:
the butyl will be too big to fit in the channel so if you pull it, it will thin up and just put enough in to barely fill the channel. when you make it all the way back around make sure you over lap the butyl so it doesnt have a gap where the two meet. go ahead and screw the top turn signal reflector screws back in from the back side of the housing now. make sure they are tight because the rubber washer seals moisture out.
next its baking time once again. what i did was put the lens on the lights once you get the butyl laid in the channel and put everything in the oven. this way everything is warm when going back together and you get a good seal. preheat the oven to 265 degrees and stick it in the oven for 7 1/2 minutes. press the lights together and try to get the clips to lock back in. some of my clips were pretty beat up from prying the lights apart but its okay if they all dont lock it. i only had 1 or 2 not lock in and they are holding fine. i cooked the light for an extra 3 1/2 minutes and pressed together again just to be safe. trim any extra butyl off if it pours over the edge. i didnt have any that looked like a problem so i just left it go. install the last screw in the bottom back of the headlight housing now that the lights are back together, once again make sure its tight the rubber washer seals moisture out. here is the final product once i got them out of the oven. !!!!!!! :liar:
im giving them a few days to cure because my buddy was doing the retro fit at the same time as me and i was doing this out of extra headlights where he wasnt and needed them back together. he didnt order the dust caps so i had to let him have mine while i wait for the dust caps to arrive lol. should be in friday. so once i get them i will get pics of final wiring and install as well as silicone the wires coming out of the housing and sealing up around the strobes ( you can see the extra holes in the top reflectors
buck russell
Pennsyltucky
Nice write up, sir. Well done.
Thanks for your contribution and taking the time to make a thread. Defintely something I want to tackle this summer.
Josh@DirtyDiesels
PA
Thanks for your contribution and taking the time to make a thread. Defintely something I want to have someone install for me this summer.
Fixed it....
Headlights look sweet Travis! Makes me want to do them on my 6.0.
travisH3
Cincinnati, Ohio
Sorry if I missed it, but where can you get the clear reflectors from?
well what happened was i ordered brand new head lights that came from ebay and they were chrome with clear reflectors. after i baked them apart I seen the adjuster screw for the headlight aiming was stripped so i bought another set of factory headlights and used the clear reflectors on the oem ones. im not sure if anyone will sell you just clear reflectors though
smokinstroker
Still need to get a mini and measure it. I only want to do this if I can get one in the top blinker housing as well.
The square form in new to me, actually fits those headlights pretty well.
Diesel23
NWI
really SWEET! Travis nice job and they look frikkin awesome , i love the parking lights set up
travisH3
Cincinnati, Ohio
EDIT: 6/28/14
got the dust caps in. the d2s bulb plugs are at a 90 degree angle so thats why i had to put the wires coming out the dust caps out the side but it gives you more room behind the headlight when installing. i sealed up the holes with clear silicone around the wires and make sure you wiggle the wires around to make sure silicone is all the way around the wires so no leaks. I put silica gel packs behind the reflectors of the lights for absorbing any moisture in case any got in there but its been raining and super humid here and no moisture at all in the head lights. i was able to get them aimed decently last night so i'm excited and think they look good. still cant beat the led light bar for high beams only. the light it puts out is amazing. anyways heres some pics of the headlights buttoned up in the back and a few pics i snapped with my phone of them installed.
