1000 RWHP Build for the summer
ingrahams
New Hampshire/Africa
well I am back in Africa, had a great time with the truck for the last three weeks, still fighting the surging/bucking which is really starting to frustrate the sh!t out of me, one way or another it will be figured out on my next trip home, brakes and the PMF short arm kit also need to go on and may 1st its being dropped off to get the battrys relocated and some of the wiring cleaned up then it's getting a different degas bottle and different windshield wiper resevoir and possibly a trutrack for the rear.
-Stew
ingrahams
Got my truck back from getting the battery's relocated, turned out way better then I was expecting. Next up are the brakes and 4 links.
-Stew
Kind
Those red tops will tuck up inside the frame as well instead of hanging down and in the open.
Super08Duty
College Station, TX
Good luck with your optimas. Mine yellow tops only lasted 6 months before I had to jump the truck off Everytime I started it. Went back to acid filled batteries and have had much better luck. Optimas aren't made by the same company anymore from what my battery guy told me.
Kind
My reds lasted me 5 years.
Sent from my subconscious to your screen.
ingrahams
the air filter will be getting changed out in july when i get home, probably something like what Eric's running on his truck.
They hang lower than I would have liked but the truck will never be offroad so it doesn't matter.
I allready had the optimas and mount when you told me your experience in another thread.
-Stew
ive never been around rust like that, sure sucks.
Batteries came out good i really like that weight is where it needs to be
Diesel23
NWI
Stew , man really looks sharp , so what's the plan for filling the space where the other battery was ? Another TURBO LOL !! You have an animal thats forsure very nice
ingrahams
I have a few plans for the future, for now I have a moroso tank that is made to fit in where battery's do that I am going to use for a windshield washer reservoir so I can fit a new filter set up.
ingrahams
Well finally got home and got some more work done on the truck, installed the willwood front brakes and all I have to say is holy sh!t do these things make a big difference, worth every penny.
Made my own intake so I could fit a 5X12 AFE filter with help from BigR and then tackled the Midwest duel fueled kit, install went fine with just some minor adjustments on the fuel lines to clear MPDs race manifolds. Then came the hot pipe between the two turbos, this is when I came to respect the skills of the fabricators out their a whole lot more, what a pain in the ass to get things lined up tight and perfect. It will get a new pipe made when I have time but for now the heat wrap hides my mess pretty well.
Right now I am having issues with the charging system, it seems to only start charging when voltage drops to 11.5 then it cuts back out a few seconds later. The guys that moved the batteries put a 200 amp breaker on the power cable to the starter and alternator and that keeps blowing as well. The air dog seems to be getting very hot also, not sure if that is normal or not.
I'll get some pictures up soon.
-stew
RSK
Connecticut
-stew
Damn, are the brakes more like a car now? as in you barely touch them and it stops almost instantly and if you hit them like before you can send the passenger into the windshield?
forcefed6.4ford
Medicine Hat... Again
What do the willwoods run? Do you know off hand if they make anything for a 450? I was on their site a while back and I just seemed to be running circles. Called there sales dept and was on hold for too long. Got bored and bought stock pad and rotors haha.
Crack85
Midland, Tx
3k for the fronts 3k for the rears so 6k and nothing for f450.
Administrator
and the dude there is kind of a dik...
