Need help on hpo system
smokedout250
harrisburg oregon
So I have an issue and It comes down to the hpo system. At wot the truck flat falls on it's face... Cts is showing any where from 2.8-3v under wot runs... Runs great and is a beast on the bottom end... Now I've been told it could be anything in the system... Oil rails, the nipples on the oil rails, injectors, injector orings... I'm at a loss on where to start, I have no long cranks, cold start is normal other than a little stiction, hot starts are perfect... Runs perfectly fine just falls on it's face... I need ideas on what to look for where to start diagnosis and all around ideas...
I ran it at the track laid down a whopping 14sec quarter 1.8 60ft 1600*egt, no boost leaks, no Exhuast leaks... Couldn't even break 90mph....
Mods:
205/75s
Ported intake
S368
Rr, a1000 65psi sump
Gearhead tunes
Built trans
Craig@MFI
Sounds like injectors are cut ti big or crappy seals
Sent from my SAMSUNG-SM-N900A using Tapatalk
Craig@MFI
Worn springs inside could be a lot of things but definitely injector related
Craig@MFI
I'm would be willing to bet on its injector related
