Wireless air bag controller
leland88
Warman Saskatchewan Canada
so i finally decided that im going to put riderite 2535 bags in my truck unless someone has something better to point me to but my question is the wireless controller
which one is better and why? what the difference? how is the range and battery life?
riderite dual wireless remote 2541
or
air lift wireless air 72000
Sent from my SGH-I747M using Tapatalk
dseitler
Royal Palm Beach, FL
It might sound crazy but I installed a Neway from a Peterbilt air leveling valve to the bottom of the pickup box above the rear axle. I attached the rod to the bolt on top of the rear axle housing. At the outlet of the valve bag side I installed a 0-5V sensor and programmed it into my Edge CTS. In the inlet of the tank I have a 100psi shutoff switch that is powered by my outfitters switch then goes through a relay to power the compressor. I have the ride height set where I want empty end up being around 4lbs. I never touch it. Every time I hook up to a trailer or load something in the truck it takes care of itself. I had to put a orfice in the dump side to slow the air way down or the compressor would run more than I liked. Just a idea.
leland88
I dont have the cts to do that. And that was something i thought of doing but i wiressless kit just seems easier
jcain
Have fun building that bag kit. What a joke. I'll never recommend airlift for this platform.
zporta
I have the air lift kit and seems to be pretty high quality. Yea there are a lot of parts but once you start assembling it takes no time at all
Josh@DirtyDiesels
PA
or
Shoot me an email or a pm. We can go over some options... I can set you up with what you need.
zporta
Ok do the remote battery last long?
I don't have the wireless, because it isn't conpatable with onboard air compressors. It only works with having the compressor hooked straight to the bags.
I have a 2.5 gallon tank that feeds the bags and train horns and other things
Tank
http://i265.photobucket.com/albums/...A-E9B6-4FBD-B5D2-0ED4AE229FEF_zpsyqle64gf.jpg
Compressor
http://i265.photobucket.com/albums/...3-642C-45F8-A571-EE551BB78E1E_zpsohwephku.jpg
Horns
http://i265.photobucket.com/albums/...B-8C56-4BFE-B606-CC670D1CB0A3_zpsgft7zz9e.jpg
Bags
http://i265.photobucket.com/albums/...D-BC9F-43D0-84D5-AAF59A885EB6_zpsedmexmyr.jpg
Air chuck
http://i265.photobucket.com/albums/...9-90C0-4EA9-B908-67F026738A3E_zps4vpgo2uf.jpg
Air controller
http://i265.photobucket.com/albums/...0-4649-4EA9-8A79-744AF68572FE_zpssenkf3bg.jpg
Pstrke96
Dunnellon fl 34433
I have done several ride rite kits high quality easy install never did a wireless
But my oldest set is on it's 3rd ruck and probably close to 500 k never lost a bag and only had one cracked line since 1998
WHY NOT
Carlyle IL
I use the air lift wireless one controller on my truck. It works well. I just keep extra batteries on hand. I have had them die on me before right when I put a large load on the GN
WHY NOT
Carlyle IL
I have firestone bags on my truck. It is what we have used on all of ours in the past and they have worked great. The new air lift ones with the built in "jounce bumper" seem very neat. I think it would be good for heavy loads. Air lift makes a good product as well as firestone you won't have problems with either of the bags.
Josh@DirtyDiesels
PA
They are cool. For the reason you stated, and also that you can run them 0 psi worry free.
