Gear ratios
GO BIG OR GO HOME
Graham, NC
On the differential there should be a tag with one of the cover bolts holding it on. If you read on the tag it should tell the gear ratio.... That is your best bet as long as the tag is still attached and someone hasn't re-geared the truck
Sent while doing burnouts somewhere in the country
