simple yes no wheel question straight to the point
ghostriderblk
2000 f250 2.5" rc leveling kit. Will these sizes fit with little trimming and or rubing
20x12 wheels with -46 offset - 35x12.5 m/t
20x10 wheels with -24 offset 35x12.5 m/t
Looking for people who have run them in the 99-04 trucks seems to be popular but hard to tell on lift size at pictures. Leaning toward 20x12s that have awesome deep lip I like
jwlandry
S.W. Louisiana
12 wides and 35s will require ALOT of trimming on a 2.5" leveling kit. I love ran them w a 4" and it still rubbed.
ghostriderblk
What do think about the 20x12 with 33s I'm running 33s on the stock 16s and have lots of run not turning and at full lock it barley rubs 285 width. M/t. Does the 44 offset pull the rim in closer then factory?
01pwrstkr
Polk County NC
The -44 offset sticks way outside the fenders. The higher the negative number the more they stick out. Closer to 0 or a positive number pulls them under the fenders.
"3 can keep a secret if 2 are dead"
Koda22
Ruidoso, NM
I've seen a few do 20x12 with a 33x12.50 or a 305/55/20 and only need a small amount to no trimming at all..
swinky
Eastern, Nc
35x12.50 on a 20x12 will need serious trimming
swinky
Eastern, Nc
305/50-20 on a 20x12 with a leveling kit and plenty of room.
You could easily stick a 33 under there.
swinky
Eastern, Nc
35x12.5 with a 16x10. Took the average trim and fender pull but he's only running a 2" leveling kit.
ghostriderblk
I think my problem is I like the 12 inch dish lip vs the 10 inch which has better offsets available lol. I thought the -44mm offset would bring the wheels 1-3inchs out of the fenders on a 99 to 04 and on the 05+ 3-5 inches out. I must be miss informed.
that is the first time i have read the explanation of offset wheels.. never had a clue what it all ment.
swinky
Eastern, Nc
My 12 wides are -51 and it still doesn't stick out very much.
swinky
Eastern, Nc
thats not much diffrent then the -44mm offset what size tire and lift? ill probley run a 33 with the 12 deep. are the 99-04 axels narrower then the 05+?
By about 2 inches.
305/50-20 20x12 stock height front, no block rear.
Josh@DirtyDiesels
PA
They aren't "offset wheels" the offset of the wheel is just a simple measurement and part of the specs of each and every wheel. What you are thinking of "offset wheels" is really just wheels with a large negative offset...
On topic, I don't see the 20x12 and 35s working with just a leveling kit. 20x10 should work great and still look good
