smokinstroker
who here has or is running dougs mainfold?
does it aid with spool up in a big way? what differences did you notice?
One thing I would suggest on install...measure the opening of the water neck in the front engine cover. (Where the thick black donut seal goes.) and install a frost plug there....then there is absolutley no way of having a coolant leak. (I installed the seal anyways, but it is just for vibration dampening purposes only.)
Ivan, why would there be a coolant leak there with doug's manifold over a stock manifold?
Ivan is what the french call "laissez compotent"
