Help with an engine instrument installation
Clem1226
I will be installing one of these in my truck in the next few weekends
UBG-16
I know it's a little overkill but the price was right.
I will be able to monitor.....and questions are in red
1: outside air temp___________not sure the best place to locate this probe?
2: coolant temp____________________sending unit located in coolant filter housing
3: lube oil presure__________________ where do I put this sensor? thread and pitch of the hole?
4: EGT both banks__________________1 probe in each manifold
5: fuel pressure____________________sending unit post filter on the bowl
6: HPOP pressure___________________run this off a t or y at the ICP sensor?
7: EOT____________sending unit in the top of the HPOP?
8: Transfer case temp___________Sending unit in the fluid drain hole?
9: front diff temp_____________Drill and tap?
10: rear diff temp_________Drill and tap?
11: transmission temp_________going to keep the Autometer in the port and add a sending unit to pan
12: Batt voltage____________at the batt
I will keep my pillar mount with EGT, boost and tranny temp, this will a supplemental/ troubleshooting aid as well as an overall engine condition monitor.
Any help with the above questions is appreciated...comments as well.
Tom S
UBG-16
1: outside air temp___________not sure the best place to locate this probe? Up by the grill
2: coolant temp____________________sending unit located in coolant filter housing Thermostat housing
3: lube oil presure__________________ where do I put this sensor? thread and pitch of the hole? Oil filter housing 1/8"NPT
4: EGT both banks__________________1 probe in each manifold Yes
6: HPOP pressure___________________run this off a t or y at the ICP sensor? Use another one of the head ports
7: EOT____________sending unit in the top of the HPOP? Dtill and tap
my ideas
Arisley
Arlington, Texas
For 9 and 10, instead of drilling and tapping, would it not be better to weld a bung on the cover. Just make sure it is somewhere that has clearance.
onebad7.3
MI
:whs:
I don't like the idea of drilling and tapping a diff cover
KPSquared
Wetaskiwin, AB, CAN
I would rather drill and tap the axle housing for the temp probes. It would look a lot cleaner if there wasn't a wire and probe sticking off the diff cover, and then you wouldn't have to worry when changing oil.
Guys drill and tap the diff when installing a selectable locker all the time.
Clem1226
My plan for the diff was drill and tap the housing I figured along the same line as KPS...it is done regularly with air lockers.
I have everything here, I am going to install the instrument where the the 4X4 selector would be if I had ESOF.
This all started because I wanted and OAT display.....
