SEMA 2K15 Truck Build
bigblzr94
OC
what happened to the emblem on the 4 link bars being level with the ground? sweet build.
Showoff
So, it is not complete. I would say about 60% done. Still have powder coating to do, painting to do, parts to add, etc. let's of work still to go but here are some photos you all will like!
Is the rear tirenot centered in the wheelwell?
That wheel is so nasty! It looks cool as hell!
Showoff
It's a little off. Just using a temp shackle while mine was finishing up design and being powdercoated. Once the shackles are in, it will be centered back up.
RyanOG
South, LA
Sweet truck. Do you have the contact info for Kyle at Stealth? I'd like to talk to him about running one of these kits. Also what are you doing in the rear for lift that is requiring a different shackle? Truck looks awesome and I'm really liking the 4-link arms. Looks a little higher than 8". Do you know exactly how high over stock it came out?
Showoff
Kyle's number is (shop number) is (865) 233-0076. The rear will be a block, traction bars, and an adjustable shackle (front and rear) that will give options for heights on kits. It's awesome. I'll post a pic when they get out of powder. The height is comparable to a 9-10" because I did coilovers. He can do anywhere from 2" to what I have and many different stages of a kit depending on how custom you want to go. His website should be up and running first of Nov.
