silver6four
st.charles, mo
2010 6.4..... 2 complete rocker arm assemblies... [both sides]... the gasket / fuel lines from fuel rail to injectors kit.. for rocker arm replacement... turbo U pipe seals.. i believe there is a ford kit that has all of this short of the rocker arms ...???
sunrisefordparts
Could I have you drop the crank from the list.
also I will need 6.0 rod to crank bearings instead of the 6.4 rod bearings.
Everything else will stay. I will call this afternoon to order.
Thanks
drops you down to $1023.28 with taking the crank off and updating to the 6.0 rod bearings.
sunrisefordparts
rocker arm assy list $238.10 each sell $180.00 each
top end seal kit list $677.78 sell $528.67
exhaust manifold gaskets list $15.38 each sell $12.00 each
the seal kit is everything from the head gaskets up but not the exhaust gaskets.
q#416834
shipping $20
