6.4 to 7.3 swap
BradyDisney
Thinking about swapping a 7.3/6 speed has anyone here done this? Existing threads are just telling people it's not worth it so I'm hoping you guys can help! Thanks in advance
you will find that they will tell you the same thing here..
unless the 6.4 is junk and the 7.3 is free then I could see it but most will tell you the same wherever you go..
I would do it.. but that is me...
BradyDisney
That's pretty much where I'm at.
co04cobra
WV
We did one. Worst part was the wiring was a NIGHTMARE marrying the 2 systems together.
Motor mounts slightly different. Lots of other small changes. If I did another one I would do the wiring completely different then before. There a few kits coming available where people are putting the 08 dashes in the earlier trucks.
I believe I could utilize parts of those kits and really simplify it down.
Either way though, it is a lot more work then swapping a 6.0 to 7.3.
Only pic I had right now.
BradyDisney
Wow. That's pretty wicked.. any info you can throw in on the wiring nightmare? Any little bit would help before I jump into this! Thanks for your reply
