The 2011-16 Leveled Super Duty Thread
Betarocker
Sea to Sky, BC
Wasn't the case for me with a 2.5in carli lift. Maybe because of the down travel I had? I can't imagine using stock lines for 7in lift, unless you never use the travel.
Both ends at full extension when on the hoist, with slack in the hoses. Need to use the relocatin brackets and straighten the hard lines.
JKcrawler
Finally something worth posting. I just finished up installing my Icon 2.5 and my Klutch 20x9s wrapped in 305.60R20 BFG KO2s.
Swampfox
TN
Finished up the front for now until the OUO ALA's arrive. Going to bolt up the rear bars after I get it aligned. Specs are Carli Commuter Leveling Kit minus the add-a-packs and OUO coil levelers to get the truck the same height side to side and front to back. Rear is OUO 3.625" traction block. Other than the ALA's and adding the truss with steering stabilizers pretty much done with it for now. Need to decide on some wheels/tires.
Bullet 21
Illinois
Call me crazy but I just picked up a set of platinum 20's w/ Nitto Exo Grappler 35x12.50's. Im to a point in my life that aftermarket wheels are more of a hassle than they are worth. Currently she sits on stock suspension with zero rubbing, even with the old man flaps.
Before: OEM 18's w/ 275/70r18's
After: OEM Platinum 20's w/ 35x12.50r20
looks good man! can't tell but is that a 250? and stock hight?
That does look better but the ones you took off are arguably the worst lookjng oem truck wheel ford ever used.
Colotl
2015 F250 2.5in SST Readylift
Added some new shoes! 20x9 Fuel Kranks 1mm offset with 35x12.5x20 Nitto Ridge Grapplers. No rubbing fully clocked on dirt country roads and city driving. I'm happy
Ianf2015
Hey, I have almost the exact same truck. Do U have any pics with the new bfg's on? I'm looking at tires in that size but don't want them to rub.
Ian
fam0516
2.5" on 35s
going 22x12s wanted to do a 4.5" lift but the truck barely fits in my parking garage lmaooo
Chris129
Sarasota ,FL
BDS leveling kit with BDS radius arms, Fox Resi all around and BDS 6" leaf springs with the blocks removed (rear is 2" higher) and 35x12.5x20 Toyo's .
How do you like the BDS Kit? I am looking torn between the BDS 2.5" radius arm kit and the PMF Alpha 2.5" kit with the 3- link. Anyone have any advice on which way to go? I daily drive with my truck and tow a 5K dual axle cargo trailer everyday!
